bcs001
24 days agoSophomore
Finding PIN for VOIP Phone Porting
I am porting my existing phone number FROM HughesNet TO another service and will need to provide them a PIN along with the phone number. I've looked at the online phone service portal and my detailed bill but the PIN is not shown.
Where/how do I get this PIN # from HughesNet?
Bruce
1 Reply
Sort By
This explains how to set up a pin: https://my.hughesnet.com/support/faq/538/
Sounds like you may need to set one up first and then give the number to the other service.
How do I set up my Voicemail PIN Number?
- Dial *333 on the phone you are using for Hughesnet Voice
- When prompted to enter your PIN, enter 1234.
- You will then be prompted to create a new pin. Your voicemail is now setup.
Edit: that's the only time a PIN is mentioned, btw. If you need something else, you may want to call the 800 number.
