- 11 months ago
Damian-
I see my performance is great 🙂
02/12/2024 07:43 AM320851554YesThanks 🙂
Is your ground station located in CA?
I don't know, you should have that info I would think. I had good speeds when there were 2 other storms in California.What I do know is that my speeds were good, then we had high wind gusts directly into the face of the dish, and my speeds after that went to well under 1 mps, I had 12 + mps when gen 6 was installed in the rain and clouds on 1.13.23. The wind gusts last Saturday appear causal to me , that's when my speeds slowed. Now I am supposed to wait a week until there are clear skies for a re-association, if this isn't a re-aim, I doubt it will help. Speed test just taken 608mps cloudy skies, no rain. Perhaps water in the connection of the coaxial cable (it was raining when installed) ? My bet is on the wind changing the aim, not a secure clamping of the dish. Thanks
- GabeU12 months agoDistinguished Professor IV
maratsade wrote:Is your ground station located in CA?
eco wrote:I don't know, you should have that info I would think.
maratsade isn't a HughesNet employee.
- eco12 months agoJunior
Still, it seems the wind event we had has moved the aim of the dish. Rain, clouds didn't affect my speeds, wind gusts did, the timing of the loss of speed coincided with the wind gusts. Thanks
- Damian12 months agoModerator
eco,
If the dish was not aligned properly due to wind, the dish signal quality would show a very low number or right at the bare minimum which is 60. Your signal quality is sitting well above average staying steady at 129. While I do not disagree that the mounted dish may be a bit loose, it has not shifted out of aim or position yet according to the remote diagnostics. Since the skies will remain cloudy for some time, you do not have to wait for me. If you wish to have a technician come out as soon as possible instead, you can call our support line at 1-866-347-3292 and have this requested. Also, it appears your ground station has changed after installation, and is now located in Rapid City, SD. -Damian
- 4 months ago
- 3 months ago
- 2 months ago
