sanderlay1's avatar
sanderlay1
5 years ago
Solved
Satellite Receive Signal Strength
Hello... First of all my system is working and fuctional, with the normal glitches at times.  I've been a custumer since 2009.  I'm currently using a GEN 5 service using EchoStar-17-NAD.  I'm in N...
  • sanderlay1's avatar
    sanderlay1
    5 years ago
    Thanks for the advise and help.
    Thank you for running diagnostics on the site.  I'm not surprised you found no problems, why I wanted to wait till the signal went low.  This morning the SRSS, Satellite Receive Signal Strength, is at 121.  If the SRSS stayed that way, except for normal causes, which I have already talked about in this thread, I would have no issues on this subject, a very good SRSS to say the least for anyone.  But if pattern holds it will unfortunately repeat again.   Intermittent problems are very difficult to track down and identify.
    Stevie
    sanderlay1
    5 years ago
    He redid the connections and removed an extra interconnect I was unaware of.  After powering up the modem SRSS was at 70.  I was very happy to see the problem had reared its head for the tech to see.
    He replaced the receiver and redid the ground connect.  He then went through a realignment of the dish and discovered the dish itself was tweaked preventing best signal.  The main dish assembly was put in service about July 2009 when I first became a customer.  He replaced the dish assembly and put on the new receiver and realigned.  He said he got a signal of 140 now.
    At the System Status page I got a SRSS of about 102, about 10:30 in the AM.  That's about right for the signal for when I first upgraded to Gen 5.  It would average, with no weather, 95 -105 or so.  So that works for me.
    Thank you all for your support,
    Stevie
