RiverDog
4 years agoSophomore
Slow Speed
I am having a speed problem. I am getting very slow speeds and have speed tested on testmy.net with an average 0.2 Mbps / 0.4 Mbps. I have i Windows 10 Pro system, 20Gb ram, and am directly connected...
Good Morning Liz,
RiverDog
The Archer C7 is my router. I had it connected through a switch. The router is old so it could be defective. I connected my laptop directly to the modem and still got very slow speeds, 2.38 down and .39 up. i then tested with the desktop system, with nothing else connected, and got a .10 down and a .38 up. I will pick up a new router this weekend but won't connect till we can get the problem resolved. I still can't access the WIFI on the modem. Can you retest the modem when you get time and let me know what's going on? Thanks
- 4 months ago
