WiFi is acting up
Hi so I have a problem. My WiFi is being weird sometimes the system light and sat light flash non stop other times it’s the system and signal light. Lately it’s been disconnecting and all the lights flash as if we reset it which we didn’t. We tried resetting it once and it fixed it for about a minute. I have no idea what can be causing it and its annoying cause we need it to talk to family and do work.
- Bradbslayin_1Spectator
Here is some more info we went into the SCC and there was three error codes we got 102.7.1 12.8.2 and 12.8.1. Also we have the multipath WL3000 and those are the lights i meant that where flashing cause they never had before. And it also said there was limited connection to the gateway. This started on 2-14-25. Its just confusing cause it lets us watch like streaming services but the moment we play online games it just starts to mess up.
- MarkJFineProfessor
What's likely happening is either a power brownout is causing the two modems to reset and/or the Fusion modem (the one with only 4 lights) is either having trouble connecting to a wireless tower or registering with the wireless network. This means you have regular satellite internet but the Fusion part is down. Without Fusion being fully operational you will have an immense lag playing games.
Recommend trying the following, which might get Fusion to connect properly:
1. At no time should you press any red buttons on the back of either device, nor eject the SIM on the back of the Fusion modem (WL3000).
2. If the SIM has been ejected and is sticking out from the Fusion modem, make sure it's popped back into place before proceeding further.
3. Locate the power bricks to both devices.
4. Disconnect the power cord from both bricks, noting which box loses power when you disconnect either.
5. Wait 60 seconds.
6. Re-connect one of the power cables back to the brick connected to the modem with six lights first (HT3000W).
7. Then reconnect the other power cable to the brick connected to the modem with only four lights (WL3000).The HT3000W will fully connect in about a minute, but the WL3000 may take between 6-10 minutes to fully connect and register. Your WiFi will be unstable during this time as it cycles between standard satellite and Fusion registers with the system. If after 10 minutes you still see Signal and System lights flashing on the WL3000 there is still a problem with being able to connect to the wireless network, likely requiring more help from a rep here or a tech visit.
You may want to also look at the following link using a device that is connected to the network, which may give you more clues to what is going on:
https://192.168.10.1/limited.html#!/diagnostics/instant_graphs
The information on that page should be as follows:
1. A normal Fusion system should have RSRP (wireless signal level) with a number more positive than -110. Note that a number like -120 is more negative and means the wireless signal is very marginal.
2. Public Internet: Up
3. Acceleration Appliance Status: Good - though you may see some bouncing around between this and Blackout/Brownout from the period when you rebooted the Fusion device.
4. Acceleration Tunnel Status: Not Enabled (not even sure that's implemented, tbh)
5. Management Connectivity Status: Established - though you may see two spikes MGMT Disabled from the period when you rebooted the Fusion device.
6. Wireless Receive Signal Statistics and Quality: Ignore that for now. Too complicated to explain here.
7. Wireless Receive Channel: Should show a single line for a single channel number. If it's frequently jumping around to different numbers it means it's having a problem locking on to a specific wireless channel from the nearby tower.
8. Wireless Access Technology: EUTRAN.
Hope this helps.- Bradbslayin_1Spectator
it did not work it stills just lags or straight disconnects a few minutes into playing
Those codes will need a rep here to check your modem remotely. Even with those codes, you can stream?
Yes we won’t have problems streaming things. Just when we try to do online gaming it just messes up to the point to where it will just disconnect
The lights flash when the system is in use; that's normal.
Don't reset the modem without guidance from a HN customer support person.
The next time you have issues, go to http://www.systemcontrolcenter.com/ and check the state code. If the state code is not 0.0.0, then the system detected a problem and the code will tell you what the problem is.
The HN reps on this site will be back on Monday. They can connect to your modem remotely to see if there's a problem. Keep the modem plugged in and turned on so they can connect to it.
- 10 years ago
- 10 months ago
