Hughesnet SW Buggy
Re: Hughesnet SW Buggy
The system wont, and can't show data usage for days the modem is turned off.  Have tested this theory countless times, when its off for an entire time period, then the data counters on the website totally stop till the modem is powered up, it wont reflect any usage.
@rgallenjr wrote:
Original post was asking if ANYONE was having the same problem, wasn't asking for Technical Support..
Subject: Technical issue, albeit incorrect assumption.
Post: Description of technical problem followed by more technical assumptions and snarky responses directed indiscriminantly at no particular person, "sport".
Gee, what could possibly give anyone the idea it wasn't intended as a discussion requiring technical support? 🤔
Not to mention creating yet *another* post declaiming similar incorrect technical assumptions.
Seeing a trend here...
