5 Year issue with Hughes Net
Re: 5 Year issue with Hughes Net
@bounceback2p
One thing that is of concern to Gwalk, possibly Aedan, and I is the statecode 14.1.1 being there so often...
That code essentially means that there are no devices connected by Wifi, nor Ethernet cable.  Is there a period of time during the day, where all your devices are disconnected?   Such as your computer being turned off, and any wireless devices being asleep?  This code should only ever come up when there are NO devices in communication with the unit.
That is one area to explore ... the power settings of both wired an wireless adaptors:
Yes, we've had intermittent signal and freezing.  We haven't gone down for up to a week the past couple weeks.
We don't have any Wi-Fi hooked up. We haven't connected our router for quite a while now leaving everything as connected by the installer in April. Our modem is always on and never disconnected. As far as sleep mode, we have shut that off during all this so to give as best results as we can to figure this problem out. Our computer is always on as is the modem.
@bounceback2p
Just for future reference.  When you reply to a certain post, it's a good idea to either type the person's name that you are replying to, like the following...
bounceback2p,
Such and such and such....
Or, you can type the @ symbol, and a list of the names of the people who have replied in the thread will pop up.  You can then click on the name and use that, like I did at the beginning of this reply.  This is what you will see when you type the @ symbol....
This way the intended person knows you were posting to them.  If it's just an additional post to everyone, then you don't need to do that.
It just makes it more clear as sometimes posts that are directed at a specific person may be assumed by a different person that it is directed at them.  Naming the target person allays that confusion.
@GabeU  Thanks for the info. Still new to all this and any advice is happily accepted. Thanks again and it does work LOL.
Here's the results for the speed test this morning. Will keep at it until something is figured out. Thanks to all again for your assistance. http://testmy.net/quickstats/bounceback2p
Auto-Refresh
Advanced Menu
SAI
2014428 (0x1ebcdc)
ESN
12123597
Diagnostic Code
0000-0000-0000-0005
Current State Code
0.0.0
Last Error State Code
14.1.1
Time since Recovery(d.h:m:s)
0.1:13:0
System State Code Monitor
State Code Transitions Total Duration(s) Start Time End Time Terminal Downtime
11.2.1 3265508/11/2017 02:08:0908/11/2017 02:13:140.1688%
11.2.2 6123008/12/2017 00:40:1808/12/2017 00:43:480.0782%
11.2.5 337008/04/2017 20:18:4908/04/2017 20:21:340.0235%
11.3.1 1115808/12/2017 00:43:4808/12/2017 00:43:580.0100%
12.1.9 217108/04/2017 22:21:2908/04/2017 22:21:440.0109%
12.3.1 21808/11/2017 02:06:0708/11/2017 02:06:180.0011%
14.1.1 10095780808/12/2017 09:49:5608/12/2017 10:41:0560.8877%
20.1.1 150151108/08/2017 02:32:3508/08/2017 02:32:440.0961%
20.2.1 57608/04/2017 20:21:4408/04/2017 20:21:500.0048%
21.1.4 11008/04/2017 20:21:5008/04/2017 20:22:000.0006%
21.1.5 11608/04/2017 22:12:5408/04/2017 22:13:100.0010%
23.1.1 43108/11/2017 22:24:0308/11/2017 22:24:110.0020%
30.3.4 5161907/30/2017 15:15:0307/30/2017 15:25:020.1029%
Percent Time Spent in State (Since Startup)
@GabeU@Gwalk900@C0RR0SIVE@AedanHere are the results of tonights tests. This is from Testmy.  http://testmy.net/quickstats/bounceback2p
This is the Hughes SCC at the same time.
Auto-Refresh
Advanced Menu
SAI
2014428 (0x1ebcdc)
ESN
12123597
Diagnostic Code
0000-0000-0000-0005
Current State Code
0.0.0
14.1.1
0.0:1:47
11.2.1 3265508/11/2017 02:08:0908/11/2017 02:13:140.1637%
11.2.2 6123008/12/2017 00:40:1808/12/2017 00:43:480.0758%
11.2.5 442008/12/2017 21:45:4508/12/2017 21:46:350.0259%
11.3.1 1222808/12/2017 21:46:3508/12/2017 21:48:050.0141%
12.1.9 217108/04/2017 22:21:2908/04/2017 22:21:440.0105%
14.1.1 10396705508/13/2017 01:02:4608/13/2017 01:25:5059.6253%
20.1.1 150151108/08/2017 02:32:3508/08/2017 02:32:440.0932%
20.2.1 57608/04/2017 20:21:4408/04/2017 20:21:500.0047%
23.1.1 43108/11/2017 22:24:0308/11/2017 22:24:110.0019%
30.3.4 7215908/12/2017 18:26:0608/12/2017 18:30:060.1331%
 We are about ready to give up. This is the same as its always been. Run test after test and nothing comes of it only promises unfulfilled. If we had another option for internet in our area, we'd been gone long time ago. But since we don't, we're stuck and just have to deal with it. Thanks to all who have tried to helped. We'll see for a couple more days IF anything comes of this from corporate or our credits we've been promised. Not holding our breath though.
Is your computer directly connected to the HT2000w?  It's not going through any other devices what so ever, such as a network switch or Hub?
What's the exact model of your computer?
@C0RR0SIVE  Our computer is hooked up direct to the modem. There is nothing else hooked up....no router, no network nor HUB.
We have a HP Pavilion 23 with a 23 inch diagonal screenwith full HD IPS display. 64 bit with 20GB of memory. Hope this is the information you were asking for.
