5g WiFi Connection
5g WiFi Connection
For some reason my computer nor wireless printer seem to see the 5g connection option; only the 2g.   It works and shows on both my phone and my husband's phones, but it will not show up in the computer network options nor the printer.   I've gone in to the system page to check to ensure nothing had gotten disabled.   Any suggestions or help would be appreciated.
4 REPLIES 4
Re: 5g WiFi Connection
A lot of computers and printers do not have the 5g option yet.
@dodsondj87
Have you ever been able to connect the two devices in question to the 5Ghz band before, like with a previous router?
If not, it may be like @gokartergo24 stated, in that those two devices don't have the ability to connect to the 5Ghz band.  Many devices out there can't (neither my laptop, nor notebook, can), though many newer ones have that ability.
I have the same problem---my phone and tablet connect to 5g but my older laptop does not.  Is there any difference in data speed between the two connections?
There can be.  Sometimes the throughput on the 2.4GHz band is lower.
One way you can check is, on the laptop that is connected to the 2.4GHz radio, click on the following link and see what result it gives you.  Again, make sure to do this on the laptop in question.  It will give you the throughput of the method with which you are connected, in this case being the 2.4GHz band.
http://192.168.0.1/limited.html#!/general/lan_speed
P.S.  This link will give you the throughput on any device you are connected with as long as you click on it while using that device.
Edit:  Just to be clear, this only tests the throughput between the modem and your device, not your internet speed.  If it's above your internet speed, you should be fine.  If it's lower than your internet speed, it can cause issues with that device...internet speed wise, that is.
