coppcabin
Over the past 10 months my modem keeps going offline on a daily basis whenever internet is in use.  The internet goes down and when I check the modem all the lights on the front are off.  I have to reset power each time to get the internet to come back up.  This is a major frusteration becuase it occurs at random, sometimes several times a day and other times it happens late at night, and some days it doesn't happen at all (although it's rare).  This modem is at a second home that is only used every other weekend or so, and the service only tends to go out when somebody is actually there using the internet.  The modem normally stays online when nobody is home.  I can tell because I have a remote weather station and security camera, both of which will go offline if the internet is down.
I have been working with tech support chat and just received a replacement modem and power supply, and the same exact thing is happening with the new equipment.  The new modem worked for about 3 hours today before the internet went down, and as always, when I checked it all the lights were out on the front.  I reset the power and everything came back up.  The service is not usable in this condition.  I really need a solution to this!
1 ACCEPTED SOLUTION
Accepted Solutions
coppcabin
Re: All lights on front of modem keep going out!
Liz-
Tech came out and was a helpful guy.  He did not opt to replace the modem since it's been swapped twice already.  He said he updated the software on my existing modem and he also found that the coupler that connects the indoor and outdoor coax runs between the modem and the satellite was lose.  He tightened the connection and asked that I let him know if I continue to have problems.  Due to it being winter, I'm at the property very little so it may be a while before I am able to confirm if I'm still having problems.  I will post back once I get a chance to use the service again.  Thanks!
-Kent
22 REPLIES 22
@coppcabin
What is the modem plugged into?  I ask this because you mentioned that you have to "reset the power."  What is it you do when you reset the power?
Hi coppcabin,
  I see it's your first post here, so welcome to the community! Thanks for reaching out, this sounds very peculiar. As Gabe previously stated, I'm curious as to what power source the HughesNet modem is connected. Are you connected to a UPS? A power strip? A wall outlet?
If you're not already connected to a wall outlet, please do so to see if you notice a difference. The diagnostics I've run on your site don't indicate anything out of the ordinary with the HughesNet system.
Your cooperation and patience are much appreciated. Looking forward to hearing back.
Slow performance? Click me!
coppcabin
Hi, and thanks for the quick replies!  Power is plugged into a Tripplite Isobar surge protector.  I do have other network components in the surge protector and have no problems with the other devices.  However, in case the surge protector is faulty, I have also plugged the satellite modem directly into the wall outlet, but the same problem occurs.
coppcabin
By resetting the power, I mean that I simply unplug the power cord from the power source and plug it back in.  The satellite modem will not reset on it's own once all the lights on the front go out.  Strangely, the link lights on the back of the modem for the wired Ethernet ports continue to show activity even when all the lights on the front of the modem go out.  However, wired devices also don't work and can't access internet when the problem occurs.  It's almost as if the satellite modem is in stand-by with power applied but it's not booted up and running.
Hi coppcabin,
Thank you for the additional details, let me investigate further into this for you. I'll post back once I have any updates or additional questions.
Hi coppcabin,
If you could please answer these questions as well, they can help our investigation:
Does the issue persist even when the modem is the only device plugged into that wall socket?
--A similar case from long ago involved a modem didn't like sharing a socket with a fridge, and more recently, an a/c unit.
Since you mentioned this system is in a second home, are there any devices or appliances that get powered on and used only when you're at that home?
Do you have a CB radio?
--Oddly enough, this has affected a customer's modem in the past.
The next time you lose connectivity please browse to your System Control Center (SCC) at 192.168.0.1 and click on System Status at the top of the page.
Note the State Code, which is a series of 3 numbers separated by dots. 0.0.0 is the state code for a fully operational system.
If you can't access the SCC, let me know if you can access 192.168.42.1.
  Your cooperation, patience, and understanding are much appreciated, looking forward to hearing back.
coppcabin
Liz-
I don't know for sure what else is on the circuit, but the only other devices plugged into the outlet are a small network switch and a wireless receiver for the internet connected weather station.  I will be at the home this weekend and will verify what else is on the circuit.  That said, there isn't anything that is turned on in the cabin when we are there that isn't normally turned on when we aren't there.  No, I don't have a CB radio.
When the lights go out on the modem and the internet goes down, I can't access anything with wireless devices since the wireless goes offline immediately at the same time.  As I mentioned in the above post, wired devices can't access internet either when the problem occurs.  However, I don't recall if I have tried accessing the modem management at 192.168.42.1 via a wired device or not, so I will try that the next time it goes down.
Since I will be there this weekend, please let me know if there's anything else I can check.  Thanks!
-Kent
Thanks Kent!
I have some troubleshooting steps to try when you get back to the cabin.
Try to use the internet until the connection drops. When this happens and the LEDs are off again, leave the modem alone. Give it 20 minutes to see if it will come back online on its own, so no rebooting.
If the modem never comes back online, check the state code in the SCC; it's best to try on a PC/laptop hardwired directly to the modem, same goes for trying the 42.1 address.
Finally, please have just the modem plugged into the wall outlet to see if the issue persists.
Let us know how it goes!
coppcabin
I wasn't able to make it to the cabin this past weekend as planned, so I will have to test the next time I'm there.  Please keep this thread open.  I'm not at the site very often but when I am this is a major frusteration.  I will post an update as soon as possible with responses to your quesitons.  Thanks!
