Cannot connect to wireless HP D110 printer with Gen5 wireless
Mike Finn
can not connect the printer
2 REPLIES 2
Distinguished Professor III
Re: Cannot connect to wireless HP D110 printer with Gen5 wireless
I've had that happen to me.  I solve it by deleting the printer and installing it again, and that works for a while.
C0RR0SIVE
Are you having issues connecting your printer to the wifi network?  OR, are you having issues connecting your device to your printer over the network?
If the later of the two, you will need to delete, and attempt to reinstall your printer on your device.
Otherwise, if you are having issues getting the printer to connect to your wifi network, please try the following....
Your device may not support the Wifi Encryption method the HT2000w uses by default, this could be due to the age of the device, or software of the device. In the case of a Wireless adapter for your computer, please make sure you have the latest drivers installed. You can usually download the drivers from the manufacture of your computer, or of the wireless adapter.
To change from the default WPA2 AES encryption method to WPA/WPA2 TKIP+AES mode, please follow the steps below.
1: In your browser go to http://systemcontrolcenter.com or http://192.168.0.1
2: On the left hand side, click on "Wifi Settings"
3: You will be presented with a logon screen, the default password is admin
4: Select either 2.4Ghz, 2.4Ghz Guest, 5Ghz, or 5Ghz Guest, which ever network your device is trying to connect to
5: Select the WPA Mode and set to WPA/WPA2 - the Cipher Suite should change from AES to TKIP+AES
6: Click Save Settings
7: Try to reconnect your device using the proper password for the wifi network.
