Connection was reset
Re: Connection was reset
I am still having this problem. This morning I connected directly to the modem while having this problem, instead of using WIFI. Same problem exists so I did a speed test ........... the results:
Perform 10 web responsiveness tests and post.  Same page as the Speed test.
Web response tests; later ones today were taken using WIFI, earlier ones were taken while directly connected to modem.
Those aren't bad.  A little slow.  Good numbers are like 0.2 sec.  Mine varied all over the place up to 90 seconds.
WVmom, you may want to read this: http://forums.rockyou.com/showthread.php?t=55358
Here is a test to run: https://www.poodletest.com/
Read here also:  https://threatpost.com/google-removes-sslv3-fallback-support-from-chrome/109455
Note Stephanie's problem in the comments.
Sorry, one more read: https://www.facebook.com/MafiaWarsAddon/posts/860649290660562
Point is pretty sure that error is not Hughes fault. Appears to be a Chrome problem as they have dropped SSLv3 support. You could try FireFox.
I tried FireFox when the problem first presented. Thanks for any and all suggestions. I am willing to read any help you offer.
Very nice of you, appreciate the kind words.
Might also contact FaceBook as to why they are still using SSLv3 since it has been a known vulnerability for months now.
One more about FireFox:  http://www.zdnet.com/article/firefox-releases-version-34-with-sslv3-fixes-firefox-hello/
Good morning WVmom21 and sgoshe,
Those posts and links are similar to the ones I've come across while researching that error message. Other Zynga users accessing FarmVille/FV2, regardless of ISP are experiencing the same error message. I'm also inclined to agree with sgoshe that this error is due to something on Zynga's end.
Given that your browser is updated, SSLv3 is disabled, which is good, so the error message implies that Zynga may still have SSLv3 enabled on their FarmVille servers. This discrepancy between your browser (client) and the Zynga servers is what's causing that error to display.
I've passed on this info to our resident game gurus just so they have this on their radar just in case we get more reports like yours. I wish we could do more to help, but at this point, I would also let Zynga know this error persists. Thank you again for your cooperation and patience as we worked to help address your concerns.
Thank you, Liz. I have contacted both Zynga and Facebook about the error messages. Have a good week, everyone!
Thank you, WVmom21, you do the same! Good luck.
