Hi, my question is should the dish be grounded outside? My dish is mounted outside of the front porch on a wood beam, and has no grounding what so ever! Does that cause a problem with static electricity be building up? Also, the bolts in the dish are rusting and creating rust trail’s down on the dish. Is that a problem? I have had the dish over two years and want the system to work as best as possible.
Also, I never had speeds over 288kbs, any information or ideals would be appreciated. thanks
