Yes, there is. Gabe gave you the link.
val_t wrote:There is no place that is suitable to do a speed test .
I don't get ads. Have uBlock. Data saver is just a word and a switch that does nothing if you ask me. You know all the tests I have done since the beginning. No sense waisting my time with 25 GB tests over and over.
Val
@val_t wrote:Data saver is just a word and a switch that does nothing if you ask me.
Video Data Saver on (default setting) vs Video Data Saver off. This is what the Video Data Saver does with the service speed while streaming. Fast dot com mimicks streaming, so it can be used to demonstrate the difference.
Your download speeds, as shown on Testmy, look fine since Jan 20th, overall. Your upload speeds are another story.
https://testmy.net/quickstats/ValT
Edit: There has only been one test run recently, and using the incorrect size.
@val_t wrote:I don't get ads. Have uBlock. Data saver is just a word and a switch that does nothing if you ask me. You know all the tests I have done since the beginning. No sense waisting my time with 25 GB tests over and over.
Val
Then it appears things are at an impasse if you won't help troubleshoot the problem. I see no link to any Testmy.net results, something they require for help with speed and buffering problems. The tests they need are 25 MB download size at various times.
Val's results link is https://testmy.net/quickstats/ValT
@maratsade wrote:Val's results link is https://testmy.net/quickstats/ValT
Thanks, didn't see it posted before.
Not very many and pretty old though. Plus looks like most on automatic file size.
Yes, that definitely needs to be addressed -- more tests, in batches, and the right file sizes.
BirdDog wrote:Thanks, didn't see it posted before.
I didn't look close enough when I made my comment above. The tests I was referring to are from Jan 20th 2018, not 2019.
I need to pay better attention.
@val_t You need to get some tests in, using the correct sizes. As others have stated, there is not going to be any help if you refuse to take part in the troubleshooting. You haven't run any tests using the correct sizes in over a year.
I would like to know what you changed in my settings please.
Reason I am asking is I have it set to 480 but will only start them in 360 even when can go higher.
You want 3 tests of 25 MB how far apart?
Val
@val_t wrote:I would like to know what you changed in my settings please.
Val
Assuming you're referring to Youtube videos, no one but you, and your speed and congestion amount, has any control over that. If you change a few to 480p and it works, they should start playing in that automatically. It has to do with what you can normally play them in. Youtube remembers your settings somewhat.
