HN7000 only three lights and tcp acceleration not operational
Advanced Tutor
Re: HN7000 only three lights and tcp acceleration not operational
It should look something like this:
My signal strength is 85
Due to bad weather this could cause the signal to degrade in strength to you
Advanced Tutor
85 is actually a decent signal level on a Ku system. You should be able to maintain a connection all the way do to around 50.
Do you have a 0.98 (~ 3') or 1.2 meter (~4') dish?
Also, let me know what your "Rate Codes" are from the HN7000S’s Advanced Configuration and Statistics internal web page.
  1. Open a browser.
  2. In the Address Bar type http://192.168.0.1/fs/advanced/advanced.html. (you can also get there from http://192.168.0.1 and clicking on the little "Service Man" icon.
  3. This should display the HN7000S Advanced Configuration and Statistics page.
  4. Click on Ranging Statistics on the left menu. In some cases, you may need to first click on Installation then Ranging Stats
  5. The following screen should be displayed:
Let me know what appears under Successful Rates, Unsuccessful Rates, and Failed Rates
Advanced Tutor
Also, what were the diagnostic codes you were seeing on the System Status page?
1.2 meter dish.
The tcp acceleration was none operational on the system status page. See below.
I'm communicating from a remote location since hughesnet is not working at my place, so I'll need to get the other information you are requesting when I get back home.
That's really looking like a transponder or Gateway issue, nothing on your end.
Advanced Tutor
Could be the transmitter. The rate codes might help to diagnose.
Good point, I forget the signal strength can be good but the transmitter still be wonky. Especially older systems, water in the radio.
Advanced Tutor
Yes. Hard to keep up on these legacy systems. I had to dust off my 7000 playbook to find the screen shots.
