Hi bfs40usa,
We can definitely help you with the service perfomance and any other concerns you might have. The best way to get the ball rolling on that is to make a new post for yourself in our community, giving us some detail on what you are experiencing, devices you are using, case numbers, etc. I would recommend the Tech category
Thanks
Is there a place on the Mac Pro like the file.net/process/iastordatamgrsvc.exe on the HP that could be a phantom using our Data? We have both computers. I have removed it from the HP.
Thank you
Macs do have the Activity Monitor, which has a Network tab. I believe this will show you what, on the Mac, is using your data. The only problem is that, I believe, the data is erased when the Mac is shut down and starts again when it's started again. I don't have a Mac, but I've read about this Activity Monitor.
'll my data gone in 17 hours & fiance out of town in another state !!!??? What gives !!!???
