I need to speak to a person with some arthority to fix my problem.
Re: I need to speak to a person with some arthority to fix my problem.
Syncing off, glasswire installed, One Drive turned off, AdBlock Plus installed, Facebook auto videos were already off. I thin that is a good start. Thanks for the help.
You are surely one of the old timers. I started out with Atari 400 as a PC in 1980 but took computer class in 1963 college, learned FAP, used a IBM 609, then later at Bell Labs no less, used punch cards to run programs in their computer center. They didn't save it on the Ark but what changes God and man hath wrought.
You're very welcome.  Don't forget about the "updates from more than one place" if you haven't already done so.  Depending on how it's set, your computer could be updating other computers on the internet.  I just keep it turned off altogether.
I hope the adjustments help.  Good luck.
