Installation Problem with the lack of system grounding.
Re: Installation Problem with the lack of system grounding.
Ditto,
Mostly it is to insure a solid copper center conductor, proper shielding and performance under a range of temp and humidty ranges.
Advanced Tutor
ok
R
Reggie, did I lose you somewhere in that last ?
Gwalk is there an identification on the cable that shows that the wire is swept or not?
Advanced Tutor
Gwalk900,
 Yes
I'm gonna learn something yet !!!
Advanced Tutor
I already did. Later.
There should be as sgoshe posted, a number on the coax.
It has been a long time since I was directly involved, but if you were to Google the number printed on the outside of the coax .. some specs should pop up.
Now, an installer would have a FSB and a list of "approved" coax, connecters and every other part that makes up an "approved" installation, includind the proper post used in post mounts.
Another common "shortcut" used by less than .... stellar installers.
Let's face a fact here .... 50% of all Doctors are in the bottom half of their grad class ... I think the percentage of installer failures is higher.
sgoshe !!! did you ever check to see if your coax ,said satellite wrote on it or not , curious  !!!
Amanda, Thank you for your help and response on this problem. The system has been repaired to the current FSB specs and installation wise I am satisfied. I appreciate your efforts.
Unfortunately it didn't correct my issue that I was having from this post.
 https://community.myhughesnet.com/hughesnet/topics/i-know-this-is-a-surprise-but-i-have-slow-speeds-...
I will post some updated information there about my situation.
Have A Great Day !!
