Something interesting I noticed. With my Dell laptop, which can only utilize the 2.4Ghz band, the speeds were the same as my desktop. Since the software upgrade to the modem, the speeds on my laptop won't climb above 41Mbps or so. My desktop still hits the high 40s, but my laptop no longer does.
I always thought it was interesting when people were seeing slower speeds with the 2.4Ghz band, as I wasn't. That's now changed. Granted, 41Mbps is still pretty darn good, but it's interesting that, since the software update, it's now limited.
Now, that's not to say that the software update necessarily has anything to do with it, but only that the speeds on my laptop dropped after said update. It could be nothing more than a coincidence.
This isn't really a problem. It's just intersting.
BTW, nothing's changed in the laptop. The only thing that's changed is the modem software.
Edit: I'm going to try my Netgear router to compare. Waiting for speed to kick back up, overall, to see if it makes a difference.
Solved! Go to Solution.
