Limited connectivity to gateway....tech support no help over phone.
Bmike254
I’ve called tech support over and over and still no help! I’m fed up. HughesNet is trash! I haven’t had internet on a consistent basis for almost a month now. They keep putting me on hold for 45 min only to lose connection aka hang up on me. I want my money back!
3 REPLIES 3
Re: Limited connectivity to gateway....tech support no help over phone.
@Bmike254
Please post a snapshot of the following page.  Make sure to edit out your SAN (starts with DSS), as this is your account number, which you should never post.
http://192.168.0.1/limited.html#!/state_code/state_code_monitor
spartanshope
I am having the same issue...here is a snapshot of my page
@spartanshope
Though your service defintely appears to be having some issues, it would be best for you to start a new topic to keep it separate from the OP's.  You can do so by clicking on the blue "Start a topic" button on the upper right while in the tech suport section.
I'd also recommend posting an updated picture in the new post.
