My late afternoon and evening speed has crashed
OK, you know I know all about peak time and other reasons for slow downs but it has been really bad for the last week or so. Decided to run automatic tests through the night and here are results that speak for themselves. It does make everything noticeably slow when this bad. Forget file downloads and streaming video.
I did set the size to 3 MB simply because it was taking forever to run with it set to 12 MB and why waste the data if the lower tests shows accurate results anyway. Speed did start to climb back up early in the morning.
Like I say, it has been going on for at least a week, I believe quite a bit longer though. I can run more tests at night if you want. Just ran another at 12 MB and it is pretty bad also.
Help please. Thank you. Signed: still Barbara.
http://testmy.net/quickstats/sgoshe
49 REPLIES 49
Re: My late afternoon and evening speed has crashed
Hello Barbara,
Do you have a router?
(forgive me Smiley Happy )
I just ran one and only got 8.02 down. Feels pretty doggie this AM.
Chicken wants his neck rung. Smiley Tongue
did you get the intended "doggie" pun in my post below?
You missed your career calling. Was you too chicken?
Yes I was.
Good morning Bar- uh, BirdDog Smiley Happy
I'll run diagnostics on your site to double-check that the equipment is OK before I send your case up to the engineers. I'll keep you posted!
See there BarbaraDog, All that barking for nothing Smiley Happy
Thanks Liz, looks like speed has yet to recover this morning, usually has by now.
