Netflicks says download speed is under 1Mbps, Hughesnet speed test says 30.26Mbps
Re: Netflicks says download speed is under 1Mbps, Hughesnet speed test says 30.26Mbps
You asked earlier how we got the Netflicks connection speed info. Open Netflicks/Get Help/Check your network/ runs connection tests of Scooection Speed. I just tried this to compare our old tower-based internet and the new HughesNet connections. The old service gave 4.93 Mbps, then switched networks and HughesNet got 0.745 Mbps.
We'll do more testmy.net tests tomorrow to finish the 3 days of tests that you requested.
Tags (1)
Senior
I think you can also run speed tests using Fast.com which is hosted by Netflix and seems to be subject to the same prioritization rules as Netflix.  At least, a few weeks ago when I was testing it on HughesNet I bascially got the same speed as on Netflix, while most other speed tests were showing much faster speeds.
Distinguished Professor III
That may activate the Video Data Saver, but I'm not sure.
Senior
My last post could be taken out of context...So to clarify, I'm not saying to use Fast.com for support here, follow the instructions you were given.  Just in general if you want to see the speeds you get from Netflix, Fast.com seems to be a good proxy.
It does.
https://community.hughesnet.com/t5/Tech-Support/An-Example-of-the-Video-Data-Saver-at-work/td-p/8226...
Good morning Jan48,
