Pi-hole might be a good solution for some people's data woes
infinitytec
Junior
Pi-hole acheives adblocking on every device by acting as a DNS server. It requires a linux computer but does not require high specs. A great benefit to using this is it blocks on every device on the network, so things like streaming sticks will not waste as much data. Probably the best way to set it up on a standard HughesNet-installed network would be to turn off DHCP on the HughesNet equipment and to enable the DHCP server on the Pi-hole.
Learn more: https://pi-hole.net/
Ryzen 7 2700/16GB RAM/X470 Motherboard/250 GB m.2 SSD/2TB HDD/4GB RX560/Windows 10 Pro
2 REPLIES 2
C0RR0SIVE
Re: Pi-hole might be a good solution for some people's data woes
Or, better yet, one could just install PFSense, SQUID, SquidGuard and PFBlocker, setup their lists and enjoy the internet ad-free, and have content filtering, as well as setup their own throttling to make sure users dont suck all the bandwidth up.
Just going to close this thread since it's gone inactive. Thanks for sharing your discussion!
