Problem with Internet Speed and 5g
Re: Problem with Internet Speed and 5g
Ok my laptop on WIFI, browsing took about 20 seconds and watching a youtube video in 1080p I had to pause it often. On my iphone and tablet everything is pretty much the same as the laptop except vidoes didn't pause as much as the laptop, but maybe because the quality was 720p. When I directly connected my laptop browsing was about 10 seconds faster than on wifi and youtube videos in 1080p had to be paused often.
Kerivor, unless you disable the Video Data Saver option on Gen5, 720p and 1080p videos will pause to buffer.  You can disable the Video Data Saver option by using the Hughesnet Usage Meter.
You can download the latest version of the Usage Meter from http://download.statusmeter.hughesnet.com/HughesNet%20Status%20Meter%20Setup.exe
I downloaded the Usage Meter and turned off the Video Data Saver and the videos are loading faster and in better quality. Hope Hughesnet can fix the 5g problem soon. Thank you for helping resolve one of my problems.
Just remember, higher resolution (clearer) videos will consume more data.
As far as the 5G fix... it's supposedly rolling out slowly, beam by beam to all customers, it may take awhile to get to you.
Hi Kerivor
Just a question... when you try looking for the 5Ghz SSID, are you very close to the modem? Also, have those devices ever been able to pick up 5Ghz?  Glad to see you got one problem fixed Smiley Happy
Deleted by me (GabeU) due to incorrect info on my part.
@GabeU wrote:
Having the Video Data Saver off has no affect on videos and lets them run as they normally would.  When it's on it restricts them to 480P, and saves data compared to what the videos would, or could, normally use.
Wrong...  The Video Data Saver option is actually intentional throttling down to ~1.5Mbps which is enough to let a 480P or lower resolution stream, but 720P and higher will buffer rather consistently. If you go to Youtube, or Netflix and set 1080p as the playback, but leave the data saver on, you will see tons of buffering.  It set to Auto, Youtube will detect the slower speed after awhile and automatically play a lower resolution.
Users are at full control of this feature and can disable it at any time.
Gabe...
When Video Data Saver is enabled this is what happens.
All video streams that Hughesnet can detect are artificially throttled to ~1.5Mbps, this causes the auto-functionality if built into a streaming player to select 480P or lower in most instances.
When Video Data Saver is DISABLED this is what happens.
All video streams are NOT throttled to ~1.5Mbps, this causes auto-detect functionality if built into a streaming player to select the highest resolution supported by the users internet connection.
There are users that manually select their resolution, and not all streaming players have auto-detect built in, it's not exactly a coincidence that his streaming started working...
