Problems with ATA this weekend
Re: Problems with ATA this weekend
Hi Bill,
Just got off the phone with an engineer; we spoke a bit about your concerns. He reassured me that if someone has unreliable power, it's perfectly OK to use a UPS. Just make sure that the UPS battery is replaced regularly. He brought this up when I mentioned that you were using your previous UPS for the past 4-5 years. An old battery in a UPS could result in the modem not getting the power it needs.
I change the battery every 2 years as APC recommends. Thanks for the info, I feel much better and will change the modem back to the UPS ASAP.
You're the best.
Very good! You're very welcome, we're always here to help.
