Red indicator light
Kg33
Red indicator light
I keep getting a message saying cannot connect to secure server. I checked the system control center and my system status light is red. I have reset the modem a few times and nothing has changed
3 REPLIES 3
BirdDog
Re: Red indicator light
Which check marks are red when you go here: http://192.168.0.1/#!/home/status  ?
When you say "reset the modem" do you mean power cycle it?
Kg33
Yes I mean power cycle it and the system status box is red when I go to that website
BirdDog
You should see check marks on the right side also like below. Would help to know which ones are red.
