Ridiculously Slow Speed
So, I've been putsing around on this community since I got my glorious Hughes Net internet installed. Glorious of course in the most sarcastic terms. I haven't experienced such slow speeds since 1996 and that's pretty horrible. Below I will post my speed test results as I've seen suggested a few thousand times. If there isn't a way to boost this with some trick can somebody please tell me how much I have to pay Hughes Net to get even mediocre speeds? I don't need more gigabytes, I just want to be able to surf the internet while I'm still young.
https://testmy.net/db/eaWfl67yo
3 REPLIES 3
Re: Ridiculously Slow Speed
@MarkHalse
For the reps to be able to help with your speed issues, they'll need some speed tests to be run at testmy.net, but they need to be run using a specific protocol.  Below is the protocol for the tests.  As stated in the instructions, the reps are on M-F, so the weekend will give you a chance to get some tests in before they're back on Monday.
To help the HughesNet Customer Service Reps get a head start on your speed concerns you should create a testmy.net account and, while signed into that account, perform 3-5 tests during different parts of the day, then share the account results link with us here.
-use the 25MB size download test file
-If testing upload instead of download, you must use a 4MB size upload test file
-post your testmy results URL here, it may look something like http://testmy.net/quickstats/yourusername
For a more in depth guide on running the tests, please visit: http://customer.kb.hughesnet.com/Pages/7001.aspx
If you are unaware of how to disable the WiFi in the HT2000W, please see "How do I manage my built in WiFi modem?" in this PDF.  Make sure to click "Save Settings" after unchecking SSID Enable for each radio individually, as unchecking all four, then clicking "Save Settings", will not hold the settings.
Hi Mark,
Just checking in - GabeU provided the essential first steps to getting your case started and help us determine what needs to be done to fix performance issues. Looking forward to your reply
Thank you,
Hi Mark,
  It's been a while since we last heard from you, so we will close this thread. If you still have concerns, please start a new thread and include a detailed explanation so we can more effectively help you.
Thank you,
