Running Speed Test for tech support
Ricky
Tutor
A friend of mine recently upgraded to Gen5. They are only getting about 8 Mbps down. I have told them to run speed test 3 times a day, 5 test each time. Is the accepted site still testmy.net? I have read there are problems with it. So should I have them run them at speedtest.com? Also they only use Ipads on the Internet. Is that acceptable now? I think they do have a laptop that can be hooked up. Does it have to be directly connected to the Gen5 modem now to run the test?
7 REPLIES 7
Re: Running Speed Test for tech support
@Ricky
Lately, the reps have been requesting tests from alternate testing sites as testmy.net is/was having issues.  It seems the issues may be resolved at this point, but the reps haven't said to start using it again, so I would advise your friend to run some tests at speedtest.net or even HughesNet's own test, or really any test they wish.  I would avoid fast.com, though, as it gets tripped up by the Video Data Saver, and when you turn the VDS off fast.com can use a LOT of data for each test.  I would also avoid any downloaded speed testing apps, like speedtest's own app, as they seem to have problems with HughesNet's latency and can give really wacky results, like upload speeds of 20Mbps.  Smiley Tongue
As for the connection, it should be a device that's directly connected to the modem with a LAN cable (no WiFi).  In addition, the WiFi should be disabled in the HT2000W while the tests are being run.  If you, or your friend, are unaware of how to disable the WiFi in the HT2000W, please see section 6 of the following PDF...
http://customer.kb.hughesnet.com/Documents/1041318-0001_a.pdf
With this said, if they don't have a device that can be connected via LAN cable and they have to use something that's connected via WiFi, please ask them to make sure that they are near the HT2000W when they run the tests.
Ricky
Tutor
Thanks GabeU. I think what I will do is take my laptop down there and connect directly to run some test. I will then run some using their Ipads to see if there is a difference. I will run them on speedtest.net.
Ricky
Tutor
Can a mod confirm which speedtest HughesNet will accept? I do not want to waste their data and my time running test on a site not accecpted.
AFAIK, Speedtest.net and HughesNet's own test are being accepted for speed tests due to the recent issues with testmy.net.
With that said, though, I'll tag the reps so that they can tell you for sure, as I know how precious data is and how we'd rather not waste it.
@Liz
@Amanda
Good morning,
According to the engineers, testmy.net is OK to use again. Thank you for checking!
Slow performance? Click me!
@Liz wrote:
Good morning,
That's great news!  Speedtest would yell at you about your ad blocker sometimes, and if you had the ad blocker disabled up to eight ads would run on that site at the same time.  It's crazy.  Smiley Tongue
Thanks.
Ricky
Tutor
Thank you for the help folks! They should be posting their results next week, I hope.
