To preface, this is more or less a continuation of a previous thread that I started regarding the titled topic...
Up until a little over two weeks ago my signal was still great, averaging from 118 to 122. I have been taking periodic snapshots of my signal strength and saving them to compare. The trees have started to fill out, so I check the strength tonight, which is a clear night, and it's now at 106. It's never been this low, not even during steady rain and heavy clouds (during storms I don't use it at all, for safety's sake). I'll keep an eye on it, but right now it is a little worrying, as the trees still have a ways to go before filled out.
I'll do a speed test later on, as right now the speed would be lower because of the time.
One thing that could be good is that I think it's one specific tree that may be causing the problem out of all of them, and I may be able to simply cut it down. I'll know for sure once the trees are full, which shouldn't be more than a couple of weeks from now.
I'm hoping that taking the snapshots of the signal strength over time, while not only helpful to me, will be helpful to the Hughesnet folks in case a real problem with the trees presents itself. Hopefully it won't.
We shall see...
There really is nothing wrong with a long and descriptive thread as others that aren't as familiar with the topic may gain insight.
I think GetSatMan fears for the tree. This is a little comical.
How dare I post such a thread!
Don't worry. If and when I have to cut down the tree, I will make sure to get your blessing. LOL.
Also, have no fear. If I have a technical question in the future, I will be oh so sure to use as few words as humanly possible, lest my thread be too long and risk sounding like I'm obsessed with the topic and going off the deep end. We can't have that! I'll try to keep it to ten words or less.
Oh darn, now this reply appears too long. I guess I will never learn.
I appreciate it. It doesn't seem to be affecting my performance in the least bit, at least not at this point. It may never. As I later found out, the small signal drop may have nothing to do with the tree at all. I'm not really concerned at this point, just more curious than anything. Hopefully it will be fine. I would be willing to bet that your tests show everything is well enough. It seems to be here.
I do know that just in the four days since starting this post, the tree in question has filled out quite a bit more, yet the signal strength hasn't dropped any more.
I'll start worrying when there is actually reason to worry, but for now, as I said, it's just curiosity. Everything's working fine.
The amount of room you have between "peak" and "cut-off" is the headroom you have as a buffer for inclement weather.Repeating that, there is no direct, 1 to 1 relationship between lower signal strength and lower speeds. These systems can maintain a fairly stable connection and speeds as long as the signal strength is within that buffer zone.
Interesting. I figured it was probably the same as my legacy system. I had a signal strength on that of about 72, on average. Sometimes during rain and such it would go down, even considerably, but it would still work and wouldn't affect the speed. The only thing it would do is if it got too low, it just wouldn't work.
I wasn't really sure if the Gen 4 worked in the same way, but after everyone's help, I understand that it does.
BTW, I know that what's going on right now, with regard to the considerable slow down in some areas, has nothing to do with signal strength. I was just being ironic, though it didn't work very well. LOL.
do you have anything better to than bash someone who is mad . kiss my ---I see one of the moderators deleted your post. Your foul-mouth posts aren't going to get you any sympathy around here.
