Re: Signal going down for some reason
This is what I saw.  Note that the signal strength went to the exact same level.  This was after resetting the modem in an attempt to fix it, which explains the low packet count.  I made sure to capture it just in case....
Senior
-Aedan
@Aedan
Ah.  Okay.  Thank you.  I figured it was something technical, as when it's been out due to a storm over the years it's acted a bit differently, with the signal strength being all over the place, and the system pretty much working immediately after that signal was back up to "strong enough", but not this time.  Plus, I know that my gateway is in Roseburg, OR, and there was nothing going on anywhere around there at the time.
Oh, wait.  Can I get a three cent offset for the month, due to it being down for a half hour?  J/K!!!  Smiley Tongue
