Signal strength and speed declined... Related?
Re: Signal strength and speed declined... Related?
I only disable web acceleration while I am using Xbox live, because the store will not load with it enabled. I do forget to turn it back on sometimes lol. I had it enabled while performing speed tests, but it doesn't seem to make a difference either way. My speeds just seem unstable, and the response time when I try to load a page seems sluggish one attempt, then it will work perfectly for the next.
Good morning Randy,
Our engineers completed work on your beam last Friday, please let us know if your browsing experience has improved.
We eagerly await your reply.
Hi Randy,
It's been over a week since we last heard from you, so we will close this thread. If you still have concerns, please start a new thread so we can address them.
