I am having a speed problem. I am getting very slow speeds and have speed tested on testmy.net with an average 0.2 Mbps / 0.4 Mbps. I have i Windows 10 Pro system, 20Gb ram, and am directly connected to the modem with a new cat 6 cable. The system is up to date and uses Bitdefender Total for antivires and firewall protection. I use Superantispyware for malware and it showes clean. This has been going on for a couple of months but recently became very slow. I also can't access the WIFI settings in the modem, it previously worked but now won't accept the "admin" password. any suggestions?
Solved! Go to Solution.
Good Morning Liz,
