I am receiving slow speeds for the past 120 days, HugesNet's speed test shows results of .21 Mbps several times. I have rebooted modems, routers with no increases in speeds. This is worse than 56k dial up modems I used in the past. Certainly not what we are paying for. I have results from speed testing sites that HughesNet referred me to previously. It was showing less than 1 Mbps speeds several times tonight.
:::.. Download Speed Test Result Details ..:::
Download Connection Speed:: 396 Kbps or 0.4 Mbps
Download Speed Test Size:: 1.3 MB or 1280 kB or 1310720 bytes
Download Binary File Transfer Speed:: 50 kB/s
Tested At:: http://TestMy.net Version 15
Validation:: http://testmy.net/db/RGLM34FVx
TiP Measurement Summary:: Min 0.15 Mbps | Middle Avg 0.5 Mbps | Max 1.24 Mbps | 157% Variance
TiP Data Points:: 0.45 Mbps, 0.7 Mbps, 0.88 Mbps, 0.89 Mbps, 0.65 Mbps, 0.25 Mbps, 0.16 Mbps, 0.18 Mbps, 0.34 Mbps, 0.72 Mbps, 0.78 Mbps, 0.34 Mbps, 0.4 Mbps, 1.24 Mbps, 0.24 Mbps, 0.15 Mbps, 0.21 Mbps, 0.4 Mbps, 0.44 Mbps
Client Stats:: http://testmy.net/compID/6618128277840
Test Time:: 2016-12-19 13:48:02 Local Time
Client Location:: US http://testmy.net/country/us
Target:: Miami, FL http://fl.testmy.net
Client Host:: Hughes Network Systems http://testmy.net/hoststats/hughes_network_syste
Compare:: 5% faster than client avg, 96% slower than host avg, 98% slower than country avg, 99% slower than world index
1MB Download in 20.48 Seconds - 1GB Download in ~6 Hours - 7X faster than 56K
This test of exactly 1280 kB took 26.782 seconds to complete
User Agent:: Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko [!]
jonesfamily98092,
Below is a copy/paste of instructions on what the reps will need with regard to speed tests. The speed tests at testmy.net should be done while signed in (this makes them easier to look at later), while connected directly to the modem with a LAN cable (no router), and the download tests must be done with the manual 12MB test size.
Create an account at testmy.net if you haven't already. While signed into that account, and using a single device connected directly to the modem with a LAN cable, NO ROUTER, perform a batch of five download tests using the manual 12MB test size. Space each test at least five minutes apart. If possible, run a batch of tests a few times a day, preferably in the morning, afternoon and evening. If you can't do a batch during those times, that's okay. The important thing is to try to get some tests from different times to be able to tell when the slowdowns are happening and when they are not. This info helps them in determining what the problem could be.
After you've run some tests, post your Results page URL so the tests can be looked at. While signed in at testmy.net click on "Results". Then, while on your Results page, copy the URL and paste it into a post on here. It will look like the link below, but with your testmy account user name where it says yourusername.
http://testmy.net/quickstats/[yourusername]
