Slow speed
Slow speed
I just need some help with my speed. It seems like no matter what I am using, my allowed data or the extra that I buy, the system is really super slow. I use my internet all of the time and it does get a little frusterating to have to wait. Smiley Happy Thank you for any help you can give.
2 REPLIES 2
Re: Slow speed
manda0411, are you use to cable internet? This is high speed not broadband. Are you over your allowance? Go here and see if the two boxes at the top of the page are green: http://192.168.0.1/
Alum
Re: Slow speed
Hi Manda,
I'm sorry to hear that you are experiencing slow speeds with your service. I would like to address your concerns. To better assist you please connect your computer directly to the modem and run some speed tests for us to evaluate. Please run a set of 5 speed tests 3 times over the course of a 24 hour period for us to properly evaluate your speeds. Your patience and cooperation is appreciated, and we look forward to hearing back from you.
Speed test: http://consumer.performancetests.hughesnet.com
Thank you,
Chris
