Slow speed
lucyjanney
Slow speed
Haven't even had hughesnet for 30 days yet and have consistently had slow speeds that are typically under 1 mbps. Had the modem replaced and it's even worse. The best speeds are when I am on the phone with tech support or the tech is here. Worst ripoff ever.
Tags (1)
2 REPLIES 2
jthomas7768
Re: Slow speed
Definitely and I can’t even get on pandora locked into a 2 year contract this is BS
Re: Slow speed
Hi lucyjanney,
I see it's your first post here, so welcome to the community! We'd like to help. So we can begin addressing your speed concerns, please create a testmy.net account and run 3 tests when you normally experience a slow down. Post your test results link here in your thread.
-do the tests while directly connected to the HughesNet modem with a LAN cable (this way your Hopper and multiple Amazon devices don't interfere with testing)
-use the 25MB size download test file
