Slower than my AT&T 2 wire - Help
rmorrison9773
Purchased Hughes Net in November because my AT&T was 1.6 MBS at best.  After 2 months of Hughes Net AT&T is still better than Hughes net.  More often than not I can't even load a page when using Hughes Net.
2 REPLIES 2
Re: Slower than my AT&T 2 wire - Help
@rmorrison9773
First make sure that you are not out of data.  You can look at the HugesNet Usage Meter, or look here.  Next, take a look at this page and see if you have all green check marks down the right side of the System Status box.  If you are not out of data, and you have all green check marks, please proceed with the following speed tests...
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share the account results link with us here.
-If testing upload instead of download, you must use a 4MB size upload test file
For a more in depth guide on running the tests, please see this site (due to being an older site, the stated test sizes are incorrect for Gen5 (please use the test sizes listed in the instructions above, in bold, for Gen5)).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
Good morning rmorrison9773,
We're closing this thread since we never got a reply from you. If you still have concerns, please start a new thread and include a detailed explanation so we can more effectively help you.
Slow performance? Click me!
