Junior
Re: Speed issues, can't stay on chat for Help
@maratsade  LMAO Heart
I just meant, what would prompt her to check Smiley Very Happy
@MrBuster  10-4
Distinguished Professor III
They keep track of the posts and what we talk about -- when the tests have been done, she'll check. Smiley Happy
Junior
Well I ran several tests yesterday as per instructions (25 DL / 4 UL)
Back home now and will call them to discuss.
Why would you call them?
Do you not want the reps here to help you?  I thought that was the purpose of you coming to this support community.
Junior
Of course, that would be my preference. I didn't know if protocol was to talk to both - or?
I also didn't know how long I should give them to respond here.
Junior
If I'm on the mountain, this is all I have. I'll be back there first of next week. I had hoped all of this would get resolved on here before I left but with the ethernet connection issue my timing sucked lol
@bronccat
They normally reply within a working day of knowing that the tests have been performed, so it's likely that they will reply to help tomorrow.  I'll tag a few of them so that they will be sure to do so.
@Liz @Damian @Remy
To answer your question, you can talk to either, but I'd advise allowing the reps here to help you.  The reps here are corporate based and they have more tools readily available to help, such as direct access to the engineers, if needs be.
Junior
Yessir! Left it on for this reason.
You rock man, appreciate it!
Junior
A little LOL...
I almost ran a test here (just bc I'm new to "test.my" and realized it would look crazy. I know the location would show but didn't want to muddy the waters ;-)
Good morning bronccat,
For troubleshooting purposes, let's isolate the TV to which the Firestick is connected. I suggest documenting what happens as you go along, as I'm providing several troubleshooting steps below.
If so, please do so and temporarily disable wifi on the modem. For your convenience, here's the modem user guide. Please uncheck the SSID Enable options for both the 2.4 GHz and 5 GHz networks, as you have devices on both.
If the TV is too far to be connected via ethernet cable, disable the network on which the TV is NOT connected (2.4 GHz or 5 GHz). Be sure to disconnect any other devices that share that same network to truly isolate the TV.
If quality is already set to auto, please let me know which streaming platform you tried (Netflix, Hulu, etc.).
If no improvement in streaming via the TV, please test stream on a different device on a non-HughesNet connection, if possible. For example, if Netflix is buffering on your isolated TV, try Netflix on a mobile device via cellular connection or other non-HughesNet connection. Any difference?
The above information will help get us started on addressing your concerns, so your cooperation is much appreciated. Let me know if you have any questions about the directions above.
