Status monitor for Linux
Re: Status monitor for Linux
It took me a while to figure out how the JS on the modem was getting the information. I finally used Chromiums built in network monitor and that's how I saw the 'hidden' api pages being accessed. Once I found the hidden pages it was easy as they are just returning a small JSON structure.
I added a little code to check the amount of data returned when I'm 'pinging' the modem. It's 1004 bytes each status update.
The hidden part is probably what stopped me. I used to be more adventurous.
I've added the state codes that were kindly supplied by CORROSIVE.
I also did some other minor changes and added better state code displays in the GUI.
Just pull the new version or get the latest zip from https://github.com/bmillham/hnstatus
I've made some major updates to the monitor. It now can save status history to a sqlite3 database (configurable) You can't really do anything yet with that information, but I have plans for it ;-). There are also some bug fixes. Now the window position is saved on exit and properly restored. And I added lots more interesting information:
Please let me know if you try it out and it works for you. Or if you have problems.
Tags (1)
