Still having speed issues on Beam 55
I just ran several speed tests, using the 25 mb download test, and only two actually finished without timing out, both below 1 mbps.
I am wondering if I can be moved to a different beam again. I was moved from 39 to 55 a month ago, and the only thing that improved was signal strength but not speed.
