System will not boot
Re: System will not boot
Gateway is 0.0.0.0 with no connection. DNS is 192.168.0.1 with no connection Smiley Sad
Any news?
Hi dzfire
Sorry for the delay - I am still looking into this - I can't pin anything down on in the network that would have caused this. Can you confirm nothing changed before this happened? Bad weather, power fluctuation, moved furniture, anything outside your house?
~Amanda
No, nothing has changed. The unit is in a locked room on the top shelf plugged into a APS 1500 backup battery. We did have a dusting of snow that's melted and gone now.
Is it possible you can plug the modem into a different power source temporarily? Low power or inconsistent power may cause the outdoor radio to not have enough juice to turn on.
I tried that last night and swapped out APCs with my office one this morning. Smiley Very Happy
dzfire, I will be sending you a private message to work on this with you some more. ~A
Rgr that.
PM returned
Over 12 years and HughesNet has taken care of me again. Thanks Amanda.
