Good Morning,
For several weeks now I've been experiencing problems with very slow webpage loading, and overall sluggish behavior.
I get this 'error' that will show up in my System Control 12.1.9 A transmit problem has occured
Upon further investigation, looking at the diagnostic history, it appears to have something to do with the 'uplink'
Rebooting the modem, for a very short time, will help, but the error will come back and my service will go back to being very slow/sluggish, pages take forever to load, and overall very poor performance. I will have red X under going across the 'uplink' section of the row.
I looked around the community and noticed that @BirdDog was recently experience the same thing.
Not sure if my problem is the same, and if he was able to resolve his issues or not, but any help or advice on how to correct this continuing problem would be greatly appreciated.
I took a screen shot of my diagnostics panel this morning below..
I know that @Liz is generally out on weekends, so I decided to wait until this morning to seek advice. This issue has been going on for several weeks now. I was hoping it would clear up on it's own..but no luck so far. If anything it seems to be getting worse/more frequent.
Many thanks in advance,
Solved! Go to Solution.
Hi bare65,
This uplink state code (12.1.9) is a little different than some other ones in the community. The code you are getting generally points to a power problem, whether low or inconsistent.
The main troubleshooting step for this, as Mark states, is to ensure the power to the modem is good. Try plugging it into an outlet that does not share power with appliances and is not plugged into a surge protector/power strip. If the errors persist after that, I will have to dig a little deeper.
~Amanda
