Very Slow Speed
chevykirk
Very Slow Speed
I am New to Hughes net as of 4/10/19. My internet worked "okay" the first night, but since has been very slow all day every day.
I tried the speed test, (with wifi disabled) using testmy.net. Another thing, I noticed my data meter does not show me using any data. Any ideas?
2 REPLIES 2
Re: Very Slow Speed
@chevykirk
First, the data meter.  That's normal.  For your first twenty days of service HughesNet continually resets your data allotment.  They do this as a courtesy, so that you can update/upgrade any devices to current without having to use your normal monthly data allotment.  It's more or less like having unlimited data during this time.  After these first twenty days your data usage will start being counted normally.
For the speed issue, please be sure to run a few batches of tests at testmy.net using the protocol below.  Also, please be sure to run the tests while signed into an account that you create, as that way they are all saved in a single location, making it much easier for the reps to view.
To help the HughesNet Customer Service Reps get a head start on your speed concerns, please create a testmy.net account (if you do not already have one) and, while signed into that account, perform a batch of 3-5 tests during different parts of the day, then share the account results link with us here.
-If testing upload instead of download, you must use a 4MB size upload test file
For a more in depth guide on running the tests, please see this site (due to being an older site, the stated test sizes are incorrect for Gen5 (please use the test sizes listed in the instructions above, in bold, for Gen5)).
If you don't know how to disable the WiFi in the HT2000W, please see "How do I manage my built-in WiFi modem?" in this PDF. Please be sure to click "Save Settings" after unchecking "SSID Enable" for each of the four tabs individually (2.4Ghz, then 2.4Ghz Guest, then 5Ghz, then 5Ghz Guest).
Re: Very Slow Speed
We're closing this thread since we never got a reply from you. If you still have concerns, please start a new thread and include a detailed explanation so we can more effectively help you.
