Hi i was wondering if any of you could help me out i'm having problems with my upload speed, which is none existent. I could really use the help i'm trying to work from home but my upload speed is not what it needs to be.
What is your upload speed? Could you run a few tests over at Testmy.net (upload test, manual size 4MB) and post the link to your MyResults page? EDIT: keep in mind that the system is designed for 3Mbps of upload speed.
Make sure to also be running the tests with a device that's connected via LAN cable and with the WiFi in the modem disabled.
The full testing instructions are as follows, but in your case you'll want to focus on the upload tests, as that's what you're having a problem with...
-if testing upload instead of download, use the manual 4MB size upload test file
