Why does this work for latency?
Re: Why does this work for latency?
Oh sorry, I misunderstood then.  Well, it's a long shot but you can always try turning on Jumbo Frames.  Jumbo Frames will probably not work with your existing network, so if you do try it, make sure you are ok with your network connection dropping for a minute until you can flip it back.
