HughesNet Community
macsretandme
My problem is that about 5 days ago, out of the blue, my internet connection started dropping connections to the gateway. Based on the gateway address I believe it's out of Salt Lake City.  I've verified and double checked all of my equipment to make sure it's not the problem.  My signal strength is good, yet when I go to "system control center".  It's verified that the dropped data ranges from 0% - 80% randomly.  When checked further, problems keep pointing back to associated gateway problems.  Is there anyway to change associated gateway to a different location other than SLC?
1 ACCEPTED SOLUTION
Good morning macsretandme,
Edit:
Slow performance? Click me!
17 REPLIES 17
