has anyone downloaded 10.1 and is having problems with excessive data allowance depletion. do i had to go back tp 8.1 to resolve problem
has anyone downloaded 10.1 and is having problems with excessive data allowance depletion. help do i had to go back tp 8.1 to resolve problem
1 ACCEPTED SOLUTION
Accepted Solutions
Re: has anyone downloaded 10.1 and is having problems with excessive data allowance depletion. do i had to go back tp 8.1 to resolve problem
Hi farmerhugh,
Welcome to the community and thanks for posting. Check these instructions on how to enabled metered connections: http://lifehacker.com/enable-metered-connection-to-delay-windows-10-updates-1723316525
Let us know if you need additional assistance.
6 REPLIES 6
Win10.1 doesn't exist... It's just Win10... If you are experiencing data loss with Win10 you may want to read the following topic as Win10 can upload updates to other users on the internet, thus depleting your allowance.
https://community.myhughesnet.com/hughesnet/topics/disappearing-data-windows-10-updates
i meant 10--is there any way to stop this.  i know it updates on its own.  i am the only user
go to your network connections and set them as metered connections
i cant seem to  find that,  is there a download manager that would work
Hi farmerhugh,
Could also be OneDrive if you set it up during the windows 10 install process, you can turn it off by right clicking on the little cloud icon in the task bar and select options and uncheck the start when windows boots then reboot your computer
