iMessage: images fail to upload
Re: iMessage: images fail to upload
You're welcome! Just got off the phone with engineering, they'll monitor and run some tests on your site over the next few days to see why your outgoing iMessages may not be working. I'll post back once I have news.
Hi maratsade,
Can you please test if iMessaging works normally for you now and a couple more times in a few hours as well? The more data points engineering has to reference, the better.
Distinguished Professor III
Away from home until later tonight. Will test tonight and then again tomorrow morning -- hope this is OK?
Sure!
OK, sent images last night, around 11 pm or so and again this morning, about 7:50 am.
The images go through, but very sloooooooooowly. This is an improvement from not going through at all. Smiley Happy
Thank you! I'll let the engineers know.
Upate, 3/10/20 @ 7:45 AM: An image I'm trying to send via iMessage is stuck at about 90% and hasn't sent. This is the same issue I had when I first posted.
Good morning maratsade,
Thank you for this news, I've sent this over to engineering to investigate. Once I have any updates for you I'll post back.
Can you please enable this LQ Image Mode setting and let me know if that makes a difference?
Implemented suggestion and at 10:49 am, not much change -- still super slow loading and sticking at the end of the upload, so it takes several minutes to load.  Will test again later and tomorrow.  Thanks for the suggestion!
