Add whatever repository Turbo Tax uses for software updates. And since it's April, those updates are like daily.
And if you can't/don't do the update, Turbo Tax quits on you...
Edit:
a104-84-185-98.deploy.static.akamaitechnologies.com:443, of course... same as the problem with Microsoft.
Great. It's spreading. This stuff may totally break CL.
Any update from HughesNet on this iMessage issue? It has been an issue for me for a few years. Clearly this is a problem on the HughesNet end, and many users are experiencing it (based on the multiple threads I have read.)
They will update us when they have an update to post.
There's nothing clear about the origin of the problem.
dtgmd24 wrote:Any update from HughesNet on this iMessage issue? It has been an issue for me for a few years. Clearly this is a problem on the HughesNet end, and many users are experiencing it (based on the multiple threads I have read.)
Hi folks!
Any iOS users still having trouble sending pictures via iMessage?
Engineering needs feedback on how iMessage is currently performing for you, this will help them in their efforts to roll out a fix.
Please send a ~3 MB picture via iMessage and note how long it takes to successfully send/return an error.
If it works, try sending a larger picture and note how long that one takes.
Also check your iMessage settings and let me know if this test was done with the Low Quality image setting enabled.
Your assistance is greatly appreciated!
iMessage images have worked for me for the last 2 days. Sending with LQ enabled.
Hello,
Thank you all for your patience while engineering investigated and addressed this. I got confirmation from engineering that they've rolled out optimization to all customers to improve iMessage/iCloud performance. I hope to see your feedback on current experiences with iMessage/iCloud, bad or good.
