my internet keep going out
WilliamHolland
the internet starting going out started saturday and still going out and it sunday and when it come out it to slow to do anything cant even get a pic posted here my info EchoStar-17-NAD, gateway ID 1, Beam ID 40, Out Beam 18 and i keep getting a lot of state codes
Tags (1)
18 REPLIES 18
Distinguished Professor III
Re: my internet keep going out
Could you post what state codes you're getting when the signal goes out?
WilliamHolland
12.1.13
12.7.1
21.1.4
23.1.1
23.1.4
30.1.1
WilliamHolland
mostly it saying  12.1.13 Transmission Problem
The HN staff on this site (you can recognise them because they have the word MOD next to their handle), can run remote diagnostics,see what's going on,  and move from there. They're here M-F, approximately 9-6.   Chat and phone support, both first tier so not as much authority to do stuff, are on 24/7.
MarkJFine
Modem can't reach the gateway. If there's not bad weather by you then there must be bad weather by the gateway.
Not familiar with E17 satellite gateway IDs, but if you know where it is you can check the weather there and see when it might clear up.
@WilliamHolland
The gateway for Beam 40 on the Echostar 17 satellite is in Salt Lake City, UT.  Though they have a Winter Storm Warning in effect from midnight tonight through 4AM Tuesday, it doesn't look like they've experienced any weather that was bad enough to cause a problem (some passing clouds is about it), so it's unlikely that weather is the cause.
If you're still experiencing the issue and don't want to wait for the reps here to help, which wouldn't be until at least tomorrow, you can call 866-347-3292 for customer support.
WilliamHolland
still going out and now mostly state code 12.1.9 -- A transmit problem has occurred
and cant call also since phone with net it going out too when net going out
Hang in there until the mods on this site research the issue and get back to you. Hopefully you'll have an answer today.
Jay
WilliamHolland,
Thank you for reaching out! I'd like to take a closer look at your account. Please see my private message for instructions.
-Jay
