need link for old status meter
Gwalk900
Re: need link for old status meter
Are you looking for the Modems internal SCC?
All Hughes modems are hardwired to 192.168.0.1
That address can not be shared with a switch, router or wireless access point or any other device.
BirdDog
So, has the new meter been updated to correct the issue with the Data Used bar at the bottom? I really don't want to re-install it just to find the problem still exists.
Gwalk900
That is what I was wondering also.
The update "nag" screen was gone for a while but now is back. It does however say V.6.5.0 rather than some newer. I can't see an updated version with the same number.
BirdDog
I wasn't getting the nag screen either for a couple days but is back now. Would like to update but not gonna do it only find the issue still there.
Hey guys,
Let me double check that for you. I know the updated version should address the main certificate error concern, not sure if the addressed the labels.
You guys have good timing. The program manager who knows all about the Status Meter updates and such is in our office today. She let me know that 6.5.2 was just released today.
I tested it in our lab and look what's back!
BirdDog
Great! I'll take the dive then knowing I shouldn't hit a rock. Thanks Liz!
Gwalk900
Thanks Liz,
Looks like it may be safe to get into the water Smiley Happy
BirdDog
Installed and seems to be working. Have to double click on tray icon to get it to expand instead of single like old one, but I can live with that.
PS: Just noticed the buy 2 get 1 free option is showing on the Purchase Tokens  screen.
