problem with iPad messaging over Hughes.net, not other networks
Re: problem with iPad messaging over Hughes.net, not other networks
Thanks Don
I have 3 iPhones, 2 run the same IOS as the iPad. The other is an older iPhone running a different IOS. I tried to clear the RAM as you suggested. The iPad still works but the phones won't. All phones worked prior to all this starting.
Ernie
Good morning all,
For any new folks, welcome and thank you for adding your input for our investigation, it's much appreciated and helpful for our case.
Kirk and wixon_kim, we have made additional adjustments to your terminals to test. Can you please let me know if iMessage works now?
Thank you,
1:43 PM EST... nope... still down
BTW, I posted a couple of longer messages this weekend with some additional thoughts about trouble shooting this problem, but I guess they got deleted.
Timed out at 1:59 PM EST
I am also in Northern California and have been experiencing the same for the last week, on all devices,
Thanks for trying and letting us know, Kirk.
Hi folks,
As our engineers continue to address this iMessage concern, please try this workaround in the meantime which should allow iMessage to work again.
Please change the DNS settings on your iDevice to a use a different DNS server such as Google's (8.8.8.8). Here are instructions on how to do so:
https://www.igeeksblog.com/how-to-change-dns-on-iphone-ipad/
Please let me know if you have additional concerns.
Advanced Tutor
Aha! That darned DNS... We've seen this before. I should have guessed that!
I've been using those for a long time now. Fewer issues. Sometimes I think the Hughes server(s) gets bogged down plus it seems it doesn't register name changes as quickly as the Google servers.
